Iris Carrier Board
Iris Carrier Board
Iris Carrier Board
(Double-Click to Zoom)
Getting Started
Toradex recommends to order the following additional products for your fist-time order:
Getting started for the first time?
For detailed step-by-step instructions about how to start with both, SoM and Carrier Board, please have a look at our step-by-step Getting-Started Guide:
Product-specific information for the Iris Carrier Board:
Having trouble?
Features
I/O Support
  • USB 2.0 (1x Host, 1x OTG)
  • I2C (1x)
  • SPI (1x)
  • UART (3x RS232)
  • PWM (4x)
  • GPIO (up to 26)
  • Analog Input (4x)
  • Ethernet (1x 10/100 Mbit)
  • SDIO/SD/MMC (1x 4 Bit MicroSD)
  • LVDS (1x Single Channel)
  • HDMI (1x, Through DVI-I connector)
  • VGA (1x, Through DVI-I connector)
  • RGB (1x 18 Bit)
  • Resistive Touch (4/5-wire)
  • Analog Audio Line in (1x)
  • Analog Audio Mic in (1x)
  • Analog Audio Headphone out (1x)
Block Diagram
* This is a module-specific feature and may not be supported by all the computer-on-modules in the Colibri family. For more details, refer to the datasheet of Colibri computer-on-modules.
Datasheets
Iris Carrier Board V2.0
Iris Carrier Board V2.0 Datasheet
Iris Carrier Board V1.1
Iris Carrier Board V1.1 Datasheet
Components
Design Resources
Iris Carrier Board Design Data V2.0
Iris Carrier Board Design Data V1.1
Please also have a look at the Iris Carrier Board Errata Document
Iris Carrier Board Mechanical Models
A basic 3D model for the Iris carrier board can be downloaded here:
Design and Layout Guide
Altium Designer
Compatible Products
[1] Capacitive Touch Adapter is required for Iris V1.1A and V1.1B, but is not required for V2.0 onwards.
[2] The LVDS cable that comes with the Capacitive Touch Display 10.1" LVDS is only compatible with Iris V2.0 onward. The LVDS signal on Iris is provided through an RGB to LVDS transmitter.
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
Iris Carrier Board
PN: 0135
01351000
Iris Carrier Board- V1.0A
Sample Version
2011-04-05
Sample Product, No PCN
01351100
Iris Carrier Board- V1.1A
Volume Production Version
2011-07-20
PCN Iris V1.1A 2017-06-20
01351101
Iris Carrier Board V1.1B
Change of micro SD card holder
July 2017PCN Iris V1.1B 2019-12-12
Update:
PCN Iris V1.1B 2021-07-21
01352000
Iris Carrier Board V2.0A
  • Major updates on: Power Supply, Ethernet, USB, Micro SD, Display interfaces, LVDS, Audio, RTC and Battery holder, see PCN document for Iris V1.1B for details
  • SHIELD/CHASSIS_GND signal connection to mounting holes and connectors body (like USB, Ethernet, DVI) have been improved for better EMC behavior.
  • Iris is now fully Industrial Temperature grade
2019-12-12PCN Iris V2.0A 2023-03-28
01352001
Iris Carrier Board V2.0B
  • Reduced USB_C_DET backfeeding current by a factor of 10: Changed R115 from 560R to 10k and R116 from 1k to 10k (details: HAR-8293)
  • Resolved RS232 transceiver backfeeding issue: Changed TI SN65C3243 with TI MAX3243IDBR (details: HAR-8294)
  • Resolve USB power switching backfeeding: Removed R156 and assembled R157 (details: HAR-8292)
Q2/2023
Errata/Known issues
Errata Document
Migration in Progress
Issue trackers are not yet available in the new developer website. See it on the archived developer website.
