Colibri Evaluation Board
(Double-Click to Zoom)
Getting Started
Toradex recommends to order the following additional products for your fist-time order:
Getting started for the first time?
For detailed step-by-step instructions about how to start with both, SoM and Carrier Board, please have a look at our step-by-step Getting-Started Guide:
Product-specific information for the Colibri Evaluation Board:
Having trouble?
Features
I/O Support
  • Up to 32 Bit External Bus
  • USB 2.0 (4x Host, 1x OTG, 1x Device )
  • I2C (4x)
  • SPI (4x)
  • UART (2x RS232, 1x RS422/485)
  • IrDA (1x)
  • PWM (4x)
  • GPIO (up to 158)
  • Analog Input (4x)
  • Ethernet (1x 10/100 Mbit)
  • SDIO/SD/MMC (1x 4 Bit)
  • CAN (1x)
  • LVDS (1x Single Channel)
  • HDMI (1x)
  • VGA (1x)
  • RGB (1x 24/18 Bit)
  • Resistive Touch (4/5-wire)
  • Camera Parallel Interface (1x)
  • Analog Audio Line in (1x)
  • Analog Audio Mic in (1x)
  • Analog Audio Headphone out (1x)
  • USB-to-RS232 Transceiver (1x)
  • RTC on Board (1x)
  • JTAG
Block Diagram
* This is a module-specific feature and may not be supported by all the computer-on-modules in the Colibri family. For more details, refer to the datasheet of Colibri computer-on-modules
** The breakout/jumper area provides a flexible mechanism for changing the hardware configuration or signal routing for any external circuit
Datasheets
Colibri Evaluation Board V3.2
Colibri Evaluation Board V3.2 Datasheet
Archive
Design Resources
Design data Colibri Evaluation Board V3.2
Design data Colibri Evaluation Board Archive
Colibri Evaluation Board Mechanical Models
A basic 3D model for the Colibri Evaluation Board can be downloaded here:
Design and Layout Guide
Altium Designer
Compatible Products
[1] Capacitive Touch Adapter is required.
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
PN: 0101
01012102Colibri Evaluation Board V2.1CInitial Version2006PCN Colibri Evaluation Board V2.1C 2012-09-21
01013100Colibri Evaluation Board V3.1A- Rearranged many connectors
- Support for USB 2.0 HighSpeed
- Support for DVI-I
- Support for LVDS
- Support for RS422/485
- Changed CAN controller, using SPI now
- Removed PCMCIA interface (CF-Card)
2012-09-12Evaluation Product, No PCN
01013200Colibri Evaluation Board V3.2AImproved flexibility:
- Added jumper for CAN RX and TX
- Added jumper for Ethernet TX Center Tap
- Connected RTS and CTS of the debug serial port to the USB to Serial port (X27)
- Camera Interface connector X22 pin-out has been updated to be compatible with Apalis Evaluation Board
2014-11-30PCN Colibri Evaluation Board V3.2A 2016-06-03
01013201Colibri Evaluation Board V3.2B- Correction of Errata: Correct Audio Connector (X26) assembled
2016-03-11
Errata
Colibri Evaluation Board Errata
