Toradex Easy Installer Configuration Files
The objective of this article is to present the configuration files and properties that allows for customization of the Toradex Easy Installer JSON files.
About Tezi Configuration Files
The Toradex Easy Installer uses JSON files for configuration, which can be edited with a text editor. Ensure compliance with the JSON specification, and use an online JSON validator like jsonlint.com for validation.
Image Format Properties
This section explains the properties used in Toradex Easy Installer's JSON image files. Toradex provides images with pre-defined JSON files, but customization is possible.
Property | Type | Description |
config_format (*) | Integer | Image configuration format |
autoinstall | Boolean | Automatically install upon image detection (default: false) |
name (*) | String | Image name displayed in the list |
description | String | Image description (tooltip) |
version | String | Image version (mostly informational) |
release_date | String | ISO 8601 date format, only informational |
u_boot_env | String | U-Boot environment file for writing. Use a text file with variable/value pairs. This file must contain the full U-Boot environment, it will not be merged with any default environment while being written. Instead, it will overwrite the default values. For more information, please access best practices |
prepare_script | String | Linux shell script executed before installation with input parameters |
wrapup_script | String | Linux shell script executed after successful installation with input parameters |
error_script | String | Linux shell script executed on installation failure. Shown in error popup with debugging info |
icon | String | Filename of the image icon (typically PNG, 40x40) |
license | String | Filename of HTML file containing the image license agreement. Requires customer agreement |
license_title | String | Title displayed in the license agreement dialog |
marketing | String | Filename of tar file with images shown during installation |
releasenotes | String | Filename of HTML file containing image release notes. Shown in a dialog |
releasenotes_title | String | Title displayed in the release notes dialog |
supported_product_ids (*) | List of Strings | List of supported Product IDs |
blockdevs (*) | List of Block Devices | List of block devices to flash (eMMC-based devices, see below) |
mtddevs (*) | List of MTDs | List of MTD devices (Linux memory technology device subsystem) for raw NAND-based devices (see below) |
isinstaller | Boolean | Special property marking the image as the Toradex Easy Installer itself |
* Mandatory properties
Mandatory Properties
Configuration Format (
config_format
):Configuration Format Minimum Toradex Easy Installer Version Reason 1 1.0 or newer 2 1.4 or newer New Features 3 2.0b3 or newer New Features (container provisioning) 4 2.0b6 or newer Bugfixes (i.MX8 u-boot environment) 5 5.6.0 or newer Add offset to Raw Files properties Block Devices (
blockdevs
): Each blockdev entry has a name and either partition or content node or both. In case of using a partition table and (raw) content, the Toradex Easy Installer will first create the partition table and then write the content according to the specification. Make sure that the partition table created and the data written do not conflict!**Property** | **Type** | **Description**
`name`(*) | String | Name of the block device to write to (as it appears under /dev/).
`erase` | Boolean | Discards all data on block device before writing (preserves Toradex Config Block on boot partition).
`table_type` | String | Partition table type (dos (default) or gpt). Use configuration format 2 or newer.
`content`(*) | Dictionary of Content | Content which should get written to the raw block device (see Chapter Content).
`partitions`(*) | List of Partitions | List of partitions which will get created and written to the block device.* Mandatory properties
Partition (
partitions
): If partitions are specified, the installer will create an MBR/DOS-style partition table. Currently, only primary partitions are supported. All partitions will be aligned to 4-megabyte boundaries (8192 blocks). A partition specification knows the following properties:Property Type Description want_maximised
Boolean Maximize partition size if multiple partitions share this setting. Distributes remaining space evenly. partition_size_nominal
Integer Minimal partition size in megabytes. offset_in_sectors
Integer Fixed partition offset in sectors (usually 512 bytes for eMMC). content
Dictionary of Content Content to be written to this partition (see below). partition_type
String Hexadecimal value for partition type (auto-determined if not specified based on filesystem_type in content). No leading "0x." Defaults to "00" (empty). active
Boolean Set as active/bootable flag (default: false). MTD Devices (
mtddevs
): Each blockdev entry has a name and either a content, ubivolumes or winceimage node.**Property** | **Type** | **Description**
`name`(*) | String | Name of the MTD device as shown in '/proc/mtd'.
`erase` | Boolean | Erase MTD partition using flash_erase (this also clears erase counters of a UBI partition).
`ubivolumes`(*) | List of UBI volumes | List of UBI volumes to create in this MTD partition.
`winceimage`(*) | Dictionary of WinCE image | WinCE image to write into this MTD partition.* Mandatory properties
UBI volume (
ubivolumes
):**Property** | **Type** | **Description**
`type` | String | UBI volume type: static or dynamic (default).
`size_kib` | Integer | UBI volume size in kilobytes. If not specified, the maximum available size will be used.
`content` | Dictionary of Content | Content which should get written in this UBI volume (see below).* Mandatory properties
WinCE image (
winceimage
): The WinCE image section allows writing a WinCE image in the sparse file format to raw NAND (uses the utility flash-wince).**Property** | **Type** | **Description**
`image_filename`* | String | Filename of the WinCE image to write.
`nonfs_size` | Integer | Non-FS size in megabyte (maximum size of the WinCE image).
`size` | Integer | The size of the image in megabytes (used for the progress bar).* Mandatory properties
Content (
content
): For block devices, content can either be raw data (dd-style) or a file system. For MTD device, content can only be raw data (uses Linux nandwrite command) and for UBI volume, content can either be raw data (uses Linux ubiupdatevol command) or ubifs.Property Type Description filesystem_type
String Type of file system (defaults to raw). Options: ext2 (1.4+), ext3, ext4, fat, ubifs, raw. label
String Label for ext3/ext4/fat file systems. mkfs_options
String Additional options for the mkfs command (ext3/ext4/fat). filename
String File name to write into the file system. Automatic extraction for zip/tar.gz/tar.xz/tar.bz2 files. filelist
List of Strings List of file names to copy into the file system. Supports tuple format (srcfile:destdir:unpack) in config v3+. uncompressed_size
Number Uncompressed size of all files in megabytes (used for the progress bar). rawfiles
List of Raw Files List of files to write using block-wise copy mode (dd) for raw file systems. Raw Files (
rawfiles
)Property Type Description filename
String File name for blockwise copy. Supports compression detection (zip/gz/xz/bz2/lzo/zst for config v3+). dd_options
String Additional options for the dd command (raw on block devices). nandwrite_options
String Additional options for the nandwrite command (raw on NAND devices). product_ids
List of String Product IDs for which this file will be copied (all supported if empty). size
Number Uncompressed file size in megabytes (used for progress bar). offset
Number Byte offset for filename write. Negative values count from partition end. (Requires "config_format": 5) rawfiles
Example
This example derived from a standard Linux image.json
file, from Verdin iMX8M Plus Tezi folder: It creates the usual two partition layout, a FAT partition for the Kernel/Device Trees and an ext3 partition for the root file system. An additional third partition has been added to create a location for user data.
The filename
or filelist
property can be used to pre-install user/application data.
"config_format": "4",
"autoinstall": false,
"name": "Toradex Easy Installer",
"description": "Toradex Easy Installer for verdin-imx8mp machine",
"version": "5.7.2+build.14",
"release_date": "2023-02-22",
"wrapup_script": "wrapup.sh",
"icon": "tezi.png",
"isinstaller": true,
"supported_product_ids": [
"0058",
"0061",
"0063",
"0064",
"0066"
"blockdevs": [
"name": "emmc",
"partitions": [
"partition_size_nominal": 128,
"want_maximised": false,
"content": {
"label": "BOOT",
"filesystem_type": "FAT",
"mkfs_options": "",
"filelist": [
"tezi.itb",
"boot-tezi.scr",
"overlays.txt"
"uncompressed_size": 44.980247497558594
"name": "emmc-boot0",
"erase": true,
"content": {
"filesystem_type": "raw",
"rawfiles": [
"filename": "imx-boot",
"dd_options": "seek=0"
Image List Format
For images loaded from an HTTP server, use an index file (typically image_list.json
) to point to individual images. It contains:
config_format (*) | Integer | The image list format configuration version, currently always 1. |
images (*) | List of Strings | List of images. This can be absolute or relative URLs. |
This example points to two images, which are located in the directories Apalis_iMX6_LinuxImage_V2.6.2
and Apalis_iMX6_LinuxConsoleImage_V2.6.2
relative to the location of this index file:
"config_format": 1,
"images": [
"Apalis_iMX6_LinuxImage_V2.6.2/image.json",
"Apalis_iMX6_LinuxConsoleImage_V2.6.2/image.json"
The Toradex Easy Installer configuration file (tezi_config.json
) allows adding additional HTTP image sources, extending the search locations for image lists beyond the pre-configured Toradex servers, e.g. to distribute images in a local network or over RNDIS. It includes:
image_lists (*) | List of Strings | List of image list sources. The absolute URL need to point to an Image List file (see above). |
show_default_feed | Boolean | If set to true the default image feed is fetched and the available images listed in the UI, else the feed is ignored. |
show_3rdparty_feed | Boolean | If set to true the 3rd party image feed is fetched and the available images listed in the UI, else the feed is ignored. |
"config_format": 1,
"image_lists": [
"http://192.168.10.2:8008/image_list.json"
