Splash Screen on Torizon OS
Torizon OS uses Plymouth splash screen running in user space. Plymouth is started from an initial minimal root file system (initramfs) very early during boot. Hence customizing the splash screen requires customizing the initramfs. Torizon OS ships with a script that allows adding a custom splash screen logo to the initramfs.
There are different phases of development with different methods for customizing the splash screen:
- Evaluation and prototyping: you can use the convenient script
ostree-customize-plymouth.sh
provided in the Torizon OS image. - Development and production: you must use the TorizonCore Builder Tool.
Limitations
The Apalis iMX8 does not have a splash screen on HDMI. The splash screen is only present when using the Capacitive Touch Display 10.1" LVDS with the HDMI Device Tree Overlay disabled.
- The custom splash screen needs to be a png file with a maximum size of your screen's resolution (-32 pixel in height for the waiting animation). Typically a resolution of around 600x400 is used. Currently, the background is always black.
- A Toradex SoM with Torizon installed.
- A Torizon OS image downloaded.
Evaluation: Add a Custom Splash Screen Directly from Torizon OS
Since the initramfs is stored in OSTree, customizing the splash screen requires a new OSTree commit. Torizon OS ships with the ostree-customize-plymouth.sh
script which does most of the work. It requires three parameters:
# ostree-customize-plymouth.sh [splash] [ostree ref] [new ostree branch]
Being:
- splash: the path to the png image.
- ostree ref: the reference to the base tree from OSTree.
- new ostree branch: the name of a new branch to which you will commit the changes.
you are advised to always start from a vanilla Torizon OS OSTree reference before running the tool for the second time.
Get the Current OSTree Reference
To get the reference to the base tree (typically the current running tree) you can use ostree admin status
to display the current reference:
# ostree admin status
* torizon e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990.0
Version: 4.0.0-devel-20200218+build.118
origin refspec: e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990
The value is displayed as origin refspec.
Create New OSTree Commit
With the png in place and the base reference above a new OSTree commit with the customized initramfs can be created. See an example below that uses an image named fast-banana.png and creates a new branch named apalis-imx6/torizon/torizon-core-docker-customized:
# sudo ostree-customize-plymouth.sh fast-banana.png \
e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990 \
Deploy New OSTree Commit
This new OSTree commit can be deployed using:
# sudo ostree admin deploy "apalis-imx6/torizon/torizon-core-docker-customized"
# sudo reboot
On reboot, you should be able to see the new splash screen showing up.
Revert to the Vanilla Torizon OS OSTree Reference
The script ostree-customize-plymouth.sh
"overwrites" the default splash screen by appending a new splash screen to the initramfs of the currently running root file system. This means that if the tool is used on an already customized root file system, the initramfs will append another splash screen, making the initramfs unnecessary larger.
Given the origin refspec from the previous example, run ostree admin switch [ostree ref]
to revert to the vanilla Torizon OS OSTree reference:
# sudo ostree admin switch e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990
# sudo reboot
Development and Production: Add a Custom Splash Screen with TorizonCore Builder
The TorizonCore Builder Tool is the recommended method for customizing Torizon OS.
Additional prerequisites
- Prerequisites from Configure Build Environment for Torizon Containers installed.
- Having read the Torizoncore Builder - Getting Started article can be helpful.
Download the setup script into some writable directory in your system (here we use
~/tcbdir/
):$ mkdir -p ~/tcbdir/ && cd ~/tcbdir/
$ wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.shnoteIf you did this before then you can skip this step unless you want to update the setup script. When you source the script (next step) it will show you a warning message if it determines an update is advisable.
Source the script:
$ cd ~/tcbdir/
$ source tcb-env-setup.shMake sure to do this from every shell instance that you intend to use with TorizonCore Builder. For advanced usage, run
source tcb-env-setup.sh -h
, or see the project README. The latter has information about using the early-access version of the tool for those interested.tip- Remember to source the setup script every time you start a new terminal (or shell instance).
- The setup script installs a Bash completion script for TorizonCore Builder, making it possible to autocomplete commands and parameters by just pressing the TAB key.
ostree serve
: consult the ostree serve reference.
Verify that the command
torizoncore-builder
is available:$ torizoncore-builder --help
Applying a Splash Screen to a Custom Image
Approach 1: Applying a Splash Screen to a Custom Image: Using the Build Command
TorizonCore Builder build command generates a custom Torizon OS image with the splash screen, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM
in the example below. This is achieved using a configuration YAML file, tcbuild.yml
as default.
It requires a Toradex Easy Installer image of Torizon OS (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar
in this case, as input. The splash screen image is passed as customization: splash-screen
# Sample configuration file:
input:
easy-installer:
#Sample customization: insert a Splash Screen
customization:
# >> Splash screen:
splash-screen: splash.png
output:
easy-installer:
The file splash.png should be available before running the build
command. A demo image can be downloaded by clicking on the link below:
Build The Custom Toradex Easy Installer Image
Build The Custom Image
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
- Using Toradex Easy Installer, the recommended method for production programming.
- Directly on the board through SSH, the recommended method during development.
- Through Torizon Cloud server, the recommended method to perform updates on a device already deployed to the field.
- It's also possible to use a static-delta approach, which is more network efficient.
Where, in my case, /media/user/myUSBstick is the path to USB stick mount point and torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM
is the directory containing the custom Toradex Easy Installer image.
Directly, through SSH
Change the argument torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM
to the directory containing your custom Toradex Easy Installer image.
Change the arguments --remote-host
,--remote-username
and --remote-password
to your board IP Address, username and password, respectively.
From TorizonCore Builder 3.1.0 after, the default value of --remote-username
is torizon
, so if the username or the password is torizon
the argument can be omitted.
Torizon Cloud
Approach 2: Applying a Splash Screen to a Custom Image: Using Standalone Commands
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom Torizon OS with the splash screen is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with different splash screens (or other customizations like different device tree overlays). As you will see, applying a splash screen to an image of Torizon OS that has other customizations is just a matter of performing the apply, merge and deploy stages.
To generate a custom Toradex Easy Installer image with the splash screen follow the sequence of steps below.
Unpack an Input Image
You just need to execute this once. Then, you are ready to apply multiple changes to the image. For example, in addition to applying a splash screen, you can also apply an external kernel module, a new device tree, among other possibilities.
If you have not unpacked an image yet, download a base Torizon OS image (preferably without containers) inside the TorizonCore Builder working directory, then run the command below to unpack it. In the example below the torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar
image is used as a reference:
If you want to change the Torizon OS base image, download the new image and run the images unpack
command again, passing the new image as the argument.
For more details about the images unpack
command, please check the images unpack command in the commands manual.
Instead of using the images unpack
you can use the images download
command. This command checks which is the connected Toradex SoM, downloads the compatible latest quarterly release of a Torizon OS image without containers, and unpacks this image.
,--remote-username
For more details on how the images download
command works, please check the images download command in the commands manual.
Apply The Splash Screen
To apply the splash screen file, in this case splash.png, to the custom Toradex Easy Installer image, run the command below:
/storage/splash/usr/share/plymouth/themes/spinner/
splash screen merged to initramfs
A demo splash.png image can be downloaded by clicking on the link below:
For more details about the splash
command, please check the spash command in the commands manual.
Merge Changes
Merge the splash screen (as well as other customizations like an external kernel module or a new device tree) into the base Toradex Easy Installer image of Torizon OS - use whatever branch name you want.
As an example, to commit changes into a branch named custom-branch
use the command below, accordingly with the TorizonCore Builder version:
$ torizoncore-builder union --union-branch=custom-branch
For more details about the union
command, please check the union command in the commands manual.
First, to generate a Toradex Easy Installer image, into the output directory torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM
Change the arguments custom-branch
to the branch where you merged the changes (with the union
command).
, --remote-host
,--remote-username
command), your board IP Address, username and password, respectively.
is torizon
Change the argument custom-branch
command).
Verifying The New Custom Image On The Device
# sudo ostree admin status
Password:
Where 58629613a342197c31c5911d0874aac1b0fcb46b68a63f59760c03bacc4df08a
is the OSTree commit hash and should be the same as:
- The one in the output of the
union
command in the case of the standalone commands - The one in the "Deploying OSTree with checksum ..." part of the output of the
build
command.
