Capturing Changes in the Configuration of a Board on Torizon OS
During the development process with Torizon OS, usually it is required to capture configuration changes on the /etc
directory that needs to be committed to the Torizon OS image.
Here are some examples of procedures that require changes in the configuration of the system:
- Custom networking configuration
- Touch screen calibration
- Cellular modem configuration
- Torizon OS boot time optimization
- Use of private registries with Torizon Cloud
- Enable additional reliability services on Torizon
- Apply udev rules to tweak configurations related to Weston
- Storage of Docker data on an external storage device (USB/SD Card)
- Enforcing strong passwords in Torizon OS
- Device Monitoring in Torizon OS
- Modifying updates configuration in Aktualizr
This article shows how to capture these system configurations.
Pre-requisites
The pre-requisite to complete these instructions are:
- Prerequisites from Configure Build Environment for Torizon Containers installed.
- A Toradex SoM with Torizon installed.
- Having read the Torizoncore Builder - Getting Started article can be helpful.
- A Torizon OS image downloaded.
Download the setup script into some writable directory in your system (here we use
~/tcbdir/
):$ mkdir -p ~/tcbdir/ && cd ~/tcbdir/
$ wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.shnoteIf you did this before then you can skip this step unless you want to update the setup script. When you source the script (next step) it will show you a warning message if it determines an update is advisable.
Source the script:
$ cd ~/tcbdir/
$ source tcb-env-setup.shMake sure to do this from every shell instance that you intend to use with TorizonCore Builder. For advanced usage, run
source tcb-env-setup.sh -h
, or see the project README. The latter has information about using the early-access version of the tool for those interested.tip- Remember to source the setup script every time you start a new terminal (or shell instance).
- The setup script installs a Bash completion script for TorizonCore Builder, making it possible to autocomplete commands and parameters by just pressing the TAB key.
ostree serve
: consult the ostree serve reference.
Verify that the command
torizoncore-builder
is available:$ torizoncore-builder --help
If you have made any configuration changes, they will be saved in the /etc
directory of your board. The isolate
command will fetch all those changes (modifications, addition, deletion, and files and directories permissions and ownership). It requires an SSH connection for the communication between the host PC and the target board.
Get configuration changes from the target board, saving them in a specific directory, in this case changes1
, with this command:
$ torizoncore-builder isolate --remote-host 192.168.1.117 --remote-username torizon --remote-password torizon --changes-directory changes1
Changes in /etc successfully isolated.
Change the arguments --remote-host
,--remote-username
and --remote-password
to your board IP Address, username and password, respectively.
From TorizonCore Builder 3.1.0 after, the default value of --remote-username
is torizon
, so if the username or the password is torizon
the argument can be omitted.
In order to keep credentials (files and directories permissions and ownership) the isolate
command will create the file /etc/.tcattr
which will be automatically used later by the union
command.
For more details about the isolate
command, please check the isolate command in the commands manual.
Applying Captured Changes to a Custom Image
Approach 1: Applying Changes to a Custom Image Using the Build Command
TorizonCore Builder build command generates a custom Torizon OS image with the captured configuration changes, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM
in the example below. This is achieved using a configuration YAML file, tcbuild.yaml
as default.
It requires a Toradex Easy Installer image of Torizon OS (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar
in this case, as input. The directory (or directories) with the captured configuration changes is passed as customization: filesystem
# Sample configuration file:
input:
easy-installer:
#Sample customization: insert the configuration changes made in the device
customization:
filesystem:
- changes1/
output:
easy-installer:
Build The Custom Image
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
- Using Toradex Easy Installer, the recommended method for production programming.
- Directly on the board through SSH, the recommended method during development.
- Through Torizon Cloud server, the recommended method to perform updates on a device already deployed to the field.
Where, in my case, /media/user/myUSBstick is the path to USB stick mount point and torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM
is the directory containing the custom Toradex Easy Installer image.
Directly, through SSH
Change the argument torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM
to the directory containing your custom Toradex Easy Installer image.
,--remote-username
is torizon
Torizon Cloud
Approach 2: Applying Changes to a Custom Image: Using Standalone Commands
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom Torizon OS with the captured configuration changes is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with captured configuration changes (or other customizations like different device tree overlays). Including a directory with captured changes on an image of Torizon OS is just a matter of passing it as a --changes-directory
argument to the union
command. Therefore, it is just necessary to perform the union and deploy stages (also the isolate
step is necessary if you want to capture the new configuration changes from the device).
To generate a custom Toradex Easy Installer image with the desired directories with captured configuration changes follow the sequence of steps below.
You just need to execute once. Then, you are ready to apply multiple changes to the image. For example, in addition to applying configuration changes captured from the device, you can also apply a custom splash screen, a new device tree, among other possibilities.
If you have not unpacked an image yet, download a base Torizon OS image (preferably without containers) inside the TorizonCore Builder working directory, then run the command below to unpack it. In the example below the torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar
image is used as a reference:
If you want to change the Torizon OS base image, download the new image and run the images unpack
command again, passing the new image as the argument.
For more details about the images unpack
command, please check the images unpack command in the commands manual.
Instead of using the images unpack
you can use the images download
command. This command checks which is the connected Toradex SoM, downloads the compatible latest quarterly release of a Torizon OS image without containers, and unpacks this image.
,--remote-username
For more details on how the images download
command works, please check the images download command in the commands manual.
Merge Changes
As a reminder, you must have captured changes as explained previously.
Merge the captured configuration changes (as well as other customizations like a kernel module or a device tree) into the base Toradex Easy Installer image of Torizon OS - use whatever branch name you want.
As an example, to commit changes into a branch named custom-branch
use the command below, accordingly with the TorizonCore Builder version:
$ torizoncore-builder union --union-branch=custom-branch
For more details about the union
command, please check the union command in the commands manual.
First, to generate a Toradex Easy Installer image, into the output directory torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM
Change the arguments custom-branch
to the branch where you merged the changes (with the union
command).
, --remote-host
,--remote-username
command), your board IP Address, username and password, respectively.
is torizon
Change the argument custom-branch
command).
Verifying The New Custom Image On The Device
# sudo ostree admin status
Password:
Where 58629613a342197c31c5911d0874aac1b0fcb46b68a63f59760c03bacc4df08a
is the OSTree commit hash and should be the same as:
- The one in the output of the
union
command in the case of the standalone commands - The one in the "Deploying OSTree with checksum ..." part of the output of the
build
command.
